Alienware x51 r3 CPU Fan Replacement
  1. Alienware x51 r3 CPU Fan Replacement, CPU Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement, CPU Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement, CPU Fan: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay down the case so that the power button is on the far right corner and is facing your right.
    • Unlock the side panel on the bottom edge by pushing its ridgeline towards the top edge. Lift the panel off of the case.
    • Peel back the cover slowly, as it will still be attached to the case by the cover lights cable. Place the panel against a clean, steady surface in preparation for the next step.
  2. Alienware x51 r3 CPU Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use either your hands or the needle nose pliers to disconnect the cable from its port on the desktop. The lighting cable will still be attached to the case.
    • Safely set down the case lid when ready to move on.
  3. Alienware x51 r3 CPU Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #0 Phillips screwdriver, remove the screws connecting the fan cover to the fan by rotating the screwdriver counter-clockwise. Lift the fan cover out of the desktop and place to the side.
  4. Alienware x51 r3 CPU Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #0 Phillips screwdriver, remove the screws connecting the fan to the motherboard by rotating the screwdriver counter-clockwise.
    • To prevent bending, try to unscrew each corner a little bit at a time, rather than unscrewing one side completely before moving onto the next.
  5. Alienware x51 r3 CPU Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using either your hands or a small needle nose plier, carefully remove cable connecting the fan to the desktop.
    • Do not rip the cable straight out. Instead, try wiggling the plier back and forth to disconnect.
  6. Alienware x51 r3 CPU Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your thumb and forefinger, pry off the four clips holding the fan to the heatsink.
  7. Alienware x51 r3 CPU Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware x51 r3 CPU Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the new or cleaned fan onto the heatsink, and press down on the corners to lock the fan onto the heatsink.
    • Make sure that the fan is positioned to blow air into the heatsink, rather than out.
After installation of the new CPU fan, the user’s computer should run more efficiently.
Dominic Stringer
crwdns2935283:002/02/21crwdne2935283:0
166 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S7-G4, Rauch Spring 2021 crwdns2935289:0Embry-Riddle Aeronautical University, Team S7-G4, Rauch Spring 2021crwdne2935289:0
ERAU-RAUCH-S21S7G4
I wish you had the heatsink for the Alienware X51 R3 desktop available.
Marcos Blanco - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 1,817
