Prerequisites
- Follow the procedure in Before working inside your computer.
Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
Lift the base cover off the palm-rest and keyboard assembly.
Disconnect the battery cable from the system board.
Turn your computer over and press the power button for 20 seconds to drain the flea power
Lift the system board Mylar and open the latch to disconnect the I/O-board cable from the system board.
Open the latch to disconnect the I/O-board cable from the I/O board.
Remove the screw (M2x4) that secures the I/O board to the palm-rest and keyboard assembly.
Loosen the captive screw (M2x2) that secures the I/O board to the palm-rest and keyboard assembly. (skip for NVIDIA GeForce RTX 3050 Ti discrete GPU controller)
Lift the I/O board off the palm-rest and keyboard assembly.
