Alienware X51 Motherboard Replacement
  1. Alienware X51 Motherboard Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
  2. Alienware X51 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
  3. Alienware X51 Motherboard Replacement, Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware X51 Motherboard Replacement, Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
  4. Alienware X51 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the Molex KK connector from the fan.
  5. Alienware X51 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware X51 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware X51 Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
  6. Alienware X51 Motherboard Replacement, Disc Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware X51 Motherboard Replacement, Disc Drive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the optical-drive data and power cable.
  7. Alienware X51 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
  8. Alienware X51 Motherboard Replacement, RAM: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware X51 Motherboard Replacement, RAM: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware X51 Motherboard Replacement, RAM: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull apart the clips that hold the RAM sticks in place.
    • Remove the RAM sticks.
  9. Alienware X51 Motherboard Replacement, Heatsink: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware X51 Motherboard Replacement, Heatsink: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware X51 Motherboard Replacement, Heatsink: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the four 10.0 mm screws around the heatsink with a Phillips #1 screwdriver until you hear a click.
    • These are captive screws and cannot be fully removed.
    • Remove the heatsink by gently prying and lifting it up.
  10. Alienware X51 Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware X51 Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 1.0 mm screw with a Phillips #1 screwdriver.
    • Firmly remove the internal PC system by lifting it out of the PC.
  11. Alienware X51 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware X51 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the four 1.0 mm screws holding down the motherboard using a Phillips #1 screwdriver.
  12. Alienware X51 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware X51 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the two SATA plugs going into the motherboard processor.
  13. Alienware X51 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the rectangular power supply plug from the motherboard into the other circuit board.
  14. Alienware X51 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the bundled cable connector going into the motherboard.
  15. Alienware X51 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the white bundled cable connector from the motherboard.
  16. Alienware X51 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the rectangular yellow bundled cable connector plug going into the motherboard.
  17. Alienware X51 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the power supply.
  18. Alienware X51 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the rectangular white bundled cable connector going into the motherboard.
  19. Alienware X51 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware X51 Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently slide and lift out the motherboard from the PC.
Braedon
crwdns2935283:010/04/23crwdne2935283:0
402 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Carnegie Fall 2023 crwdns2935289:0Eastern Washington University, Team 1-2, Carnegie Fall 2023crwdne2935289:0
EWU-CARNEGIE-F23S1G2
crwdns2942667:0crwdne2942667:0 452
