Alienware P18G M14X R1 Optical Drive Replacement
  1. Alienware P18G M14X R1 Optical Drive Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
    • The screws will not be able to be removed from the back cover. They can only be loosened or tightened.
  2. Alienware P18G M14X R1 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide back cover forward using your thumbs.
  3. Alienware P18G M14X R1 Optical Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the cover and set aside exposing the internals of the computer.
  4. Alienware P18G M14X R1 Optical Drive Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is turned off before starting.
    • Using PH1 screwdriver loosen the two screws on the right of the battery.
    • The screws will not be able to be removed from the battery. They can only be loosened or tightened.
  5. Alienware P18G M14X R1 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware P18G M14X R1 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull battery up using the tab provided.
  6. Alienware P18G M14X R1 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the clip connecting the battery to the computer.
    • Set battery aside.
  7. Alienware P18G M14X R1 Optical Drive Replacement, Optical Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
  8. Alienware P18G M14X R1 Optical Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool unclip the white connector holding down the orange cable.
  9. Alienware P18G M14X R1 Optical Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
Andonaq Grozdani
crwdns2935283:003/01/18crwdne2935283:0
892 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G2, Simcock Spring 2018 crwdns2935289:0UMass Dartmouth, Team S2-G2, Simcock Spring 2018crwdne2935289:0
UMASSD-SIMCOCK-S18S2G2
crwdns2942667:0crwdne2942667:0 545
