This guide will show you how to replace a broken optical drive. First you will need to remove the back cover then the battery in-order to get to the optical drive.
Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
Slide back cover forward using your thumbs.
Lift up the cover and set aside exposing the internals of the computer.
Using PH1 screwdriver loosen the two screws on the right of the battery.
Pull battery up using the tab provided.
Disconnect the clip connecting the battery to the computer.
Set battery aside.
Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
Using the plastic opening tool unclip the white connector holding down the orange cable.
Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
