Batteries fail from heat and if they reach their max charge cycles limit. This guide will show you how to replace it.
Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
Slide back cover forward using your thumbs.
Lift up the cover and set aside exposing the internals of the computer.
Using PH1 screwdriver loosen the two screws on the right of the battery.
Pull battery up using the tab provided.
Disconnect the clip connecting the battery to the computer.
Set battery aside.
