Alienware M17-R1 Screen Lock Assembly Replacement
    1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Open the screen until it is flat.
      • Ensure that the surface you are working on can support both the screen and the base of the laptop.
    2. Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
      • Support the screen from the bottom to make it easier to remove the screws.
    3. Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
      • Be careful not to break the face of the screen when lifting it.
    4. Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
      • Pull the assembly grip away to remove it.
      • Remove the two 5 mm screws using a Phillips #1 screwdriver.
    5. Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push in the assembly towards the spring.
      • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
      • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
    6. Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M17-R1 Screen Lock Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • If the spring is defective, slide it off the end of the assembly and replace it.
William Davis
crwdns2935283:010/09/18crwdne2935283:0
323 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S15-G2, Blackburne Fall 2018 crwdns2935289:0Sam Houston State, Team S15-G2, Blackburne Fall 2018crwdne2935289:0
SHSU-BLACKBURNE-F18S15G2
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 843
