Alienware M15x GPU Replacement
  1. Alienware M15x GPU Replacement, GPU: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over so that the bottom is facing upward.
  2. Alienware M15x GPU Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the battery latch and flip the battery out.
  3. Alienware M15x GPU Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M15x GPU Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4mm screws using a Phillips #1 screwdriver.
    • Remove the compartment door by sliding it away from the battery.
  4. Alienware M15x GPU Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4mm screws with the Phillips #1 screwdriver.
  5. Alienware M15x GPU Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the laptop vertically so that the hinge is facing up and the laptop is slightly open toward the ground
    • The laptop position should resemble an upside-down V shape.
    • Locate the panel and pry open using a plastic opening tool.
  6. Alienware M15x GPU Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M15x GPU Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M15x GPU Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the laptop normally, with the bottom on the ground and the screen flipped up towards you.
    • Lift the power button panel using the plastic opening tool.
    • Disconnect the ribbon cable by using tweezers to unclip the two small black clips. Remove power button panel.
  7. Alienware M15x GPU Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4mm screws with a Phillips #1 screwdriver.
  8. Alienware M15x GPU Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M15x GPU Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the 4mm screw from the exhaust port cover.
    • Remove the exhaust port cover entirely.
  9. Alienware M15x GPU Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M15x GPU Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M15x GPU Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 3mm screws holding the fan in place, then unclip the electrical connection using tweezers.
  10. Alienware M15x GPU Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heat sink by loosening the 4 screws with a Phillips #0 screwdriver.
  11. Alienware M15x GPU Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two screws.
    • Remove the GPU from the laptop.
    • When replacing the GPU, it is important to reapply thermal paste in a small line along the length of the chip.
Tomas Kronmark
crwdns2935283:001/22/18crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S11-G3, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S11-G3, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S11G3
crwdns2942667:0crwdne2942667:0 1,939
