Alienware M14xR2 Status-Light Board Replacement
  1. Alienware M14xR2 Status-Light Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Status-Light Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Status-Light Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Status-Light Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Status-Light Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Status-Light Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Status-Light Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Status-Light Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Turn the palm-rest assembly over.
  6. Alienware M14xR2 Status-Light Board Replacement, Remove the Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note the routing of status-light board cable and remove the cable from the routing guides.
    • NOTE: If the status-light board cable is under the speakers cable, remove the speakers cable first and then remove the status-light board cable.
  7. Alienware M14xR2 Status-Light Board Replacement, Turn the Palm-Rest Assembly Over: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  8. Alienware M14xR2 Status-Light Board Replacement, Remove the Screw: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that secures the status-light board to the palm-rest assembly.
  9. Alienware M14xR2 Status-Light Board Replacement, Lifting the Status-Light Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the status-light board and release its cable from the slot on the palm-rest assembly.
  10. Alienware M14xR2 Status-Light Board Replacement, Slide the Status-Light Board Cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the NEW status-light board cable through the slot in the palm-rest assembly.
  11. Alienware M14xR2 Status-Light Board Replacement, Align the Slot: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the slot on the status-light board with the alignment post on the palm-rest assembly.
  12. Alienware M14xR2 Status-Light Board Replacement, Replace the Screw: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the screw that secures the status-light board to the palm-rest assembly.
  13. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  14. Alienware M14xR2 Status-Light Board Replacement, Routing the Status-Light Board Cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Route the status-light board cable through the routing guides on the palm-rest assembly.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79,765 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
Völliges Durcheinander und unvollständig
Robert Fleischhauer - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 776
