Alienware M14xR2 RAM Replacement
    1. Alienware M14xR2 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in electric shock and serious injury.
      • Flip the computer upside down.
    2. Alienware M14xR2 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 RAM Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
      • The two screws are spring loaded and will not separate from the cover.
      • Slide the back cover towards you and then lift upwards to remove.
    3. Alienware M14xR2 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
      • The two screws are clipped into the battery and will not detach.
    4. Alienware M14xR2 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
      • Pull up on the white connector to disconnect it from the laptop.
      • The battery is now free to remove from the laptop and can be set aside.
    1. Alienware M14xR2 RAM Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 RAM Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 RAM Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the four 6.35 mm size 1 screws.
      • Pull up on the end of the orange tab to detach it from the white connector.
      • Lift the optical drive up and out of the laptop and set it aside.
    1. Alienware M14xR2 RAM Replacement, RAM: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 RAM Replacement, RAM: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 RAM Replacement, RAM: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the two 6.35 mm size 1 screws.
      • Lift up and remove the panel covering the RAM sticks.
    2. Alienware M14xR2 RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M14xR2 RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Push outward on both prongs that secure the RAM sticks in place.
      • The RAM sticks will rise upward when released from the prongs.
    3. Alienware M14xR2 RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M14xR2 RAM Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab and pull the RAM sticks up and out of their casing and set them aside.
Eugene Park
crwdns2935283:009/30/13crwdne2935283:0
195 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-4, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 13-4, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S13G4
How max is the ram upgrade compatible with the m14x ifixit?!
doantuan85 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yo, man! If my RAM slot is damaged somehow, is there any possibility to change/repair it? It won't detect a RAM card, keeps beeping 4 times at the start.
tasanov - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 2,740
