Alienware M14xR2 Hard Drive Replacement
    1. Alienware M14xR2 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in electric shock and serious injury.
      • Flip the computer upside down.
    2. Alienware M14xR2 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
      • The two screws are spring loaded and will not separate from the cover.
      • Slide the back cover towards you and then lift upwards to remove.
    3. Alienware M14xR2 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
      • The two screws are clipped into the battery and will not detach.
    4. Alienware M14xR2 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
      • Pull up on the white connector to disconnect it from the laptop.
      • The battery is now free to remove from the laptop and can be set aside.
    1. Alienware M14xR2 Hard Drive Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Hard Drive Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Hard Drive Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the four 6.35 mm size 1 screws.
      • Pull up on the end of the orange tab to detach it from the white connector.
      • Lift the optical drive up and out of the laptop and set it aside.
    1. Alienware M14xR2 Hard Drive Replacement, Hard Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M14xR2 Hard Drive Replacement, Hard Drive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop.
      • The screws are spring loaded and will not come loose from the hard drive assembly.
      • Pull up on the black tab gently as there is still a cable attaching the hard drive to the computer.
    2. Alienware M14xR2 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware M14xR2 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the connector that is attached to the cable at the end of the hard drive out and away from the hard drive to detach it.
      • Set aside the now disconnected hard drive.
crwdns2935229:05crwdne2935229:0
Connor Bovee
crwdns2935283:009/30/13crwdne2935283:0
569 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-4, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 13-4, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S13G4
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 11,808
