Alienware M14xR2 Display Assembly Replacement
  1. Alienware M14xR2 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Display Assembly Replacement, Removing the Mini-Card Antenna Cables: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Note the routing of the WirelessHD card (optional) and mini-card antenna cables and remove them from the routing guides on the computer base.
  6. Alienware M14xR2 Display Assembly Replacement, Turn the Computer Over: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • NOTE: The WirelessHD card is optional and may not be present in your computer.
    • Turn the computer over and open the display as far as possible.
  7. Alienware M14xR2 Display Assembly Replacement, Disconnecting the Display Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the Center-Control Cover, the Keyboard and the Palm-Rest Assembly are removed.
    • Using the pull-tab, disconnect the display cable from the connector on the system board.
  8. Alienware M14xR2 Display Assembly Replacement, Disconnecting the Logo-Board Cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the logo-board cable from the connector on the system board.
  9. Alienware M14xR2 Display Assembly Replacement, Peeling the Display Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently peel the display cable and the logo-board cable from the system board.
  10. Alienware M14xR2 Display Assembly Replacement, Remove the Screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the display assembly to the computer base.
  11. Alienware M14xR2 Display Assembly Replacement, Lifting the Display Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently slide the WirelessHD (optional) and mini-card antenna cables out through the slot on the computer base.
    • Lift the display assembly off the computer.
  12. Alienware M14xR2 Display Assembly Replacement, Placing the Display Assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the WirelessHD (optional) and mini-card antenna cables through the slot on the computer base.
    • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
    • NOTE: Ensure that no cables lie between the display assembly and the computer base.
  13. Alienware M14xR2 Display Assembly Replacement, Connecting the Display Cable: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the display cable and the logo-board cable to the connectors on the system board.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79 825 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01 991crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,760
