Alienware M14xR2 Battery Replacement
    1. Alienware M14xR2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in electric shock and serious injury.
      • Flip the computer upside down.
    2. Alienware M14xR2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
      • The two screws are spring loaded and will not separate from the cover.
      • Slide the back cover towards you and then lift upwards to remove.
    3. Alienware M14xR2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
      • The two screws are clipped into the battery and will not detach.
    4. Alienware M14xR2 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware M14xR2 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
      • Pull up on the white connector to disconnect it from the laptop.
      • The battery is now free to remove from the laptop and can be set aside.
crwdns2935229:010crwdne2935229:0
Connor Bovee
crwdns2935283:009/30/13crwdne2935283:0
569 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-4, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 13-4, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S13G4
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 11,627
