In this guide, we will be showing you how to remove and replace the Memory Modules.
Remove the two screws that secure the battery pack to the computer base.
Disconnect the battery pack cable from the connector on the system board.
Using the pull-tab, lift the battery pack off the computer base.
Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
Route the battery pack cable in the routing guide
Connect the battery pack cable to the connector on the system board.
Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
Align the notch in the NEW memory module with the tab in the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
