Alienware M11x Display Assembly Replacement
  1. Alienware M11x Display Assembly Replacement, Introduction: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • NOTE: Dell or Alienware does not guarantee compatibility or provide support for hard drives from sources other than Dell.
    • NOTE: If you are installing a hard drive from a source other than Dell or Alienware, you need to install an operating system, drivers, and utilities on the new hard drive.
  2. Alienware M11x Display Assembly Replacement, Loosen the Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the two captive screws that secure the hard-drive assembly to the computer base.
  3. Alienware M11x Display Assembly Replacement, Disconnecting the Hard-Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
  4. Alienware M11x Display Assembly Replacement, Lifting the Hard-Drive Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the hard-drive assembly out of the computer base.
  5. Alienware M11x Display Assembly Replacement, Removing the Screws from the Hard-Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  6. Alienware M11x Display Assembly Replacement, Removing the Bracket: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the hard drive away from the hard-drive bracket.
  7. Alienware M11x Display Assembly Replacement, Placing the Hard-Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the NEW hard drive in the hard-drive bracket.
  8. Alienware M11x Display Assembly Replacement, Replace the Screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the four screws that secure the hard-drive to the hard-drive bracket.
  9. Alienware M11x Display Assembly Replacement, Placing the Hard-Drive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the hard-drive assembly in the computer base.
  10. Alienware M11x Display Assembly Replacement, Connecting the Hard-Drive Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
  11. Alienware M11x Display Assembly Replacement, Securing the Screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tighten the two captive screws that secure the hard-drive assembly to the computer base.
darrius
crwdns2935283:003/26/18crwdne2935283:0
5,213 crwdns2915208:0crwdne2915208:0
crwdns2935297:030crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2942667:0crwdne2942667:0 756
