This guide will teach you how to remove the wi-fi card.
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Pull the base cover up to remove it.
If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
pulled the battery cable let it sit for ten minutes and my no post problem was fixed
thanks -
Peel back plastic cover of wi-fi card.
Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
Gently undo the clips attached to the wi-fi card.
Locate the cables that connect the wi-fi card.
Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
You don’t need to disconnect the WiFi card pins. I recommend leaving the antenna connections and just be careful when removing the frame in the next steps. The antenna connections are very fragile
I second that... Came off OK... Gently... I just can't seem to get them reconnected on renistall. Ridiculously difficult...
This step should be removed. It is completely unnecessary to entirely disconnect the Wi-Fi card. There are no clearance issues that would necessitate this - the inner case can easily be removed around it.
I agree, I did not disconnect the antenna cables after removing the WiFi card.
What is the logic for removing the HHD prior to removing the WIFI card?
