Alienware 17 R4 Battery Replacement
    1. Alienware 17 R4 Battery Replacement, Base Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
      • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
      • The M2x3 screw (1.9 mm) does not come out completely.
    2. Alienware 17 R4 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the base cover up to remove it.
      • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
      • Removing the cover may require some force.
    1. Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, Hard Disk Drive (HDD): crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
      • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
      • Failure to remove the battery connector cable properly may damage other parts of the laptop.
    2. Alienware 17 R4 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
    3. Alienware 17 R4 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently lift the HDD cable to disconnect it from the laptop.
    4. Alienware 17 R4 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the hard drive up to remove.
    1. Alienware 17 R4 Battery Replacement, RAM: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, RAM: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, RAM: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Move the metal sidings outward to release the RAM card.
    2. Alienware 17 R4 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the RAM card out towards yourself to remove it.
      • Repeat the same step for the RAM card above.
      • Slide the RAM card out carefully to avoid damaging it.
    1. Alienware 17 R4 Battery Replacement, Wi-Fi card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the WI-FI card.
    2. Alienware 17 R4 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Peel back plastic cover of wi-fi card.
      • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
    3. Alienware 17 R4 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently undo the clips attached to the wi-fi card.
      • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
    4. Alienware 17 R4 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the cables that connect the wi-fi card.
      • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
    1. Alienware 17 R4 Battery Replacement, Solid State Drive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement, Solid State Drive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
    2. Alienware 17 R4 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the solid state drive towards yourself to prevent damage to the card.
    1. Alienware 17 R4 Battery Replacement, Fan Shroud: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, Fan Shroud: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, Fan Shroud: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
    2. Alienware 17 R4 Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the plastic opening tool under the fan shroud to slowly lift it up.
      • Repeat process on the middle and opposite side.
    3. Alienware 17 R4 Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Firmly lift the plastic opening tool and pull the fan shroud towards you.
      • This will take a large amount of force and will not come out easily the first time.
      • Careful not to tear out the piece causing damage to the fan shroud
    1. Alienware 17 R4 Battery Replacement, Plastic Cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, Plastic Cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, Plastic Cover: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the two M2x3 screws (1.9 mm) at the top right and top left of the laptop that hold the tron lights in place.
    2. Alienware 17 R4 Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Follow the wiring to unplug the tron lights.
    3. Alienware 17 R4 Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the fourteen M2.5XL8' screws (2.4 mm) located in the plastic cover using the PH1 screwdriver.
    4. Alienware 17 R4 Battery Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the plastic opening tool to gently lift the sides of the cover.
    5. Alienware 17 R4 Battery Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slowly lift up the plastic cover.
    1. Alienware 17 R4 Battery Replacement, Battery: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, Battery: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Battery Replacement, Battery: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the four M2.5 screws (2.4 mm) with a PH1 screwdriver bit.
    2. Alienware 17 R4 Battery Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Battery Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the battery up to remove it.
crwdns2935229:032crwdne2935229:0
Hector Mendez III
crwdns2935283:009/11/17crwdne2935283:0
1 352 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S2-G4, Bruce Fall 2017 crwdns2935289:0CSU Fullerton, Team S2-G4, Bruce Fall 2017crwdne2935289:0
CSUF-BRUCE-F17S2G4
crwdns2935297:0108crwdne2935297:0
crwdns2947412:09crwdne2947412:0
Very good guide, just one error, step 11 comes first then step 10. You can't lift the card before remove the screw.
alex.afnet - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Great guide, no issues at all!
Glenn Bell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
First time I've cracked opened up a computer in decades. This step by step guide gave me the confidence I needed! Thank you so much. It took me longer, about two hours with stopping to label screws and things but everything is up and running again. I'm so happy!
Michelle - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I would not recommend disconnecting the wifi card. the connectors are tiny. if you screw up, best case you need a new wifi card, worst case you are going to need to replace the antenna, and that isn’t fun.
John Wohlwend - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
After the battery replacement? do we need to do anything else for calibration so that the Alienware knows that it is a fresh battery and battery cycle ... as i have heard that you need to repeat 3X the process of discharging and charging for calibration. or can we just plug and play? I am getting a new battery for mine soon. Thanks =)
Yannick Docq - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 55
crwdns2936753:030crwdne2936753:0 251
crwdns2942667:0crwdne2942667:0 39,841
