Replacing the screen of the Alcatel OneTouch Pop Icon is a difficult task that should not be attempted without proper preparation. Make sure, that when using the metal spudger that may cause electrostatic discharge, to ground yourself by touching a metal object before using the spudger.
            Shut down the device
            Flip the phone so that the screen is facing the surface you are working on
            Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
            Use your thumbnail to lift the battery from the phone.
            Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
            Using the J000 Phillips screwdriver, remove the one green 3mm screw.
            With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
            Lift the latch and gently remove the ribbon from the latch.
            Use the metal spudger to gently pry the control buttons from the case.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Using tweezers, carefully detach the antenna from the motherboard.
            Remove the tape on top of the ribbon.
            Lift the black latch to release the ribbon.
            Remove the ribbon from the latch.
            Use the tweezers to remove tape the from the top of the latch. Still using the tweezers, lift the black latch to release the ribbon.
            Remove the motherboard from the casing.
            Take a microwavable iOpener and heat it for 30 seconds.
            Use the hot iOpener to heat up the screen.
            Gently insert the plastic opening tool between the screen and the casing and use it to pry the screen loose from the casing.
            Continue prying the screen from the casing until it can be fully removed.
crwdns2935229:010crwdne2935229:0
No. Not if there fake wemon fixing things. I don't trust your company.
Cancel my order.
I don't have the tools to complete the job and repair my phone, so I'll have to get a new one but it was a very good tutorial. Lots of good pictures and very concise and clear. Thanks.
