Replacing the control buttons is a moderately difficult process that is best done if you are comfortable working with the internal components of electronics. Make sure, that when using the metal spudger that may cause electrostatic discharge, to ground yourself by touching a metal object before using the spudger.
            Shut down the device
            Flip the phone so that the screen is facing the surface you are working on
            Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
            Use your thumbnail to lift the battery from the phone.
            Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
            Using the J000 Phillips screwdriver, remove the one green 3mm screw.
            With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
            Lift the latch and gently remove the ribbon from the latch.
            Use the metal spudger to gently pry the control buttons from the case.
