In the age of evolving cell phone technology, the cameras each has is a huge factor point when buying the phone. These cameras are becoming so advanced, they are replacing the need for handheld digital cameras. Because of this, owners rely greatly on a functioning camera in their phones. This guide will provide users with information needed access and replace the camera in an Alcatel OneTouch Evolve in the case of a malfunctioning, damaged or dirty camera.
This will be an opening with enough space to insert the flat head of the plastic opening tool.
It will be located on the bottom right of the phone
Rotate the pry tool 90 degrees until the panel lifts up.
With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Unscrew each screw, counter-clockwise (left), until each one has been removed.
If necessary, use tweezers to fully remove the screws from the device.
Access the small pry tool in the tool kit
Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
Rotate the pry tool 90 degrees until part of the panel lifts up
All areas need to be fully risen off before the panel can be removed.
See yellow square for the location of the camera on the mother board.
By gently lifting the bottom rectangular piece of the camera component upwards and away from the device, the connection will come free.
Remove the rubber casing from the camera, this piece is simply resting over the camera and can easily be removed.
Place your plastic opening tool underneath the bottom of the camera and rotate the tool to lift the camera. This will take a slight amount of force.
You will start to see the silver sticky patch between the camera and the mother board - leave this on the mother board.
Keep separating the camera from the sticky patch until completely removed.
To replace camera, use the yellow lines on the motherboard as your guide.
Thank you kindly for your time to write the tutorial.
Tina Mccraney - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
