Alcatel Jitterbug Smart Charging Port Replacement
  1. Alcatel Jitterbug Smart Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
  2. Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
  3. Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
  4. Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  5. Alcatel Jitterbug Smart Charging Port Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
  6. Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to pull the black ribbon connector from its port.
    • Use a metal Spudger to gentle remove the speaker that glued at the bottom left of the phone.
    • Be careful to avoid damage the black connector or the wire connect the speaker to motherboard.
  7. Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, begin to gently pry the motherboard, away from the display assembly.
    • The motherboard will freely remove.
  8. Alcatel Jitterbug Smart Charging Port Replacement, Charging Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alcatel Jitterbug Smart Charging Port Replacement, Charging Port: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the motherboard over and desolder the charging port pin connecting on the motherboard.
    • Once pins desolder, pull off the charging port.
    • If you need helps on solder/desolder, here is the link to the soldering skills guide.
Minyu Zhang
crwdns2935283:002/13/18crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S11-G4, Cheng Spring 2018 crwdns2935289:0USF Tampa, Team S11-G4, Cheng Spring 2018crwdne2935289:0
USFT-CHENG-S18S11G4
crwdns2942667:0crwdne2942667:0 1,746
