Use this guide to replace the logic board in your Alcatel Jitterbug Smart
Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
Lift open case by the corner nearest the divot and remove it from the phone.
Remove the 13 1 mm Phillips screws with JIS #000 Screwdriver.
Gently pry off the Mid frame from the phone using a Metal Spudger.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the Plastic Opening tools to gently dislodge the broken camera from the inside of the phone.
Use a tweezers to pull the camera connector from its port.
