Akaso EK7000 4K Battery Replacement
  1. Akaso EK7000 4K Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Akaso EK7000 4K Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
    Does anyone know who sells the up and down bottom/WiFi for the akaso ek7000 4k HD camera.
    Paul Buckholz - crwdns2934203:0crwdne2934203:0
  2. Akaso EK7000 4K Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Akaso EK7000 4K Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the small plastic flap attached to the battery. Pull the battery out towards you.
    When I insert the battery ,it doesn't work so I took the battery again and I notice the terminal inside wiggling and it went out when I tilt it. How can u fix it to place back the terminal.
    Pakito Santos - crwdns2934203:0crwdne2934203:0
    Akaso ek7000 4k up&down button stuck where can I buy the part.
Annie Sun
crwdns2935283:002/05/19crwdne2935283:0
436 crwdns2915208:0crwdne2915208:0
UC Davis, Team S20-G2, Lore Winter 2019 crwdns2935289:0UC Davis, Team S20-G2, Lore Winter 2019crwdne2935289:0
UCD-LORE-W19S20G2
Thank you for the help actclly needed that help
Charisma Broughton - crwdns2934203:0crwdne2934203:0
I’ve been using my Akaso EK7000 Pro as a dashcam, I removed the battery and plugged the camera into the cars cigar lighter, now when I insert the battery the cover won’t go back on.
The battery will push down into place but when I let go to put the cover on the battery moves up and the cover is about one tenth of one millimetre too high to fit.
The camera does get quite warm when in use and I suspect the plastic of the battery chamber has slightly distorted preventing the battery going fully into it and allowing the cover to be put into place.
Do you have any suggestions how I can resolve this issue?
Glynn Sole - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,882
