Airox Legendair Battery Replacement
  1. Airox Legendair Battery Replacement, How to Properly Clean the Airox Legendair: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. Airox Legendair Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. Airox Legendair Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
  4. Airox Legendair Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure to turn off the ventilator before starting the repair.
    • Before you start the battery replacement process, make sure that the device has been placed in a clean and open environment.
  5. Airox Legendair Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove each attachment screw from the battery cover.
  6. Airox Legendair Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover carefully by holding the rails and pulling toward the rear of the device.
  7. Airox Legendair Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Extract the current battery and replace it with the new battery.
  8. Airox Legendair Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Confirm that all elements line up together. Then, reattach the battery cover with the attachment screws that were removed in Step 2.
  9. Airox Legendair Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Switch the device to "Set Up Mode" by pressing the On/Off switch.
    • Hold the menu key until the menu options appear on the screen.
    • Select the "MAINTENANCE" option with cursor.
    • Select "Voltage control" and verify that the voltage of the battery is 28.5±1V.
Perform the final inspection procedures by confirming that every screw is secure before putting back into service.
Caleb Erlenborn
crwdns2935283:004/09/20crwdne2935283:0
174 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G15, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G15, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G15
crwdns2942667:0crwdne2942667:0 471
