AirTag Battery Replacement
  1. AirTag Battery Replacement, Push down the battery compartment door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirTag Battery Replacement, Push down the battery compartment door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use both of your thumbs to push down on the battery compartment door.
  2. AirTag Battery Replacement, Rotate the battery compartment door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirTag Battery Replacement, Rotate the battery compartment door: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the battery compartment door counter-clockwise to unlatch it from the frame.
  3. AirTag Battery Replacement, Remove the battery compartment door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirTag Battery Replacement, Remove the battery compartment door: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the battery compartment door to remove it.
  4. AirTag Battery Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirTag Battery Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery.
    • When you replace the battery, insert it such that the positive end is facing up.
crwdns2935229:022crwdne2935229:0
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
46,507 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
Bjr. Plus d’un an après l’achat de l’AirTag, impossible de l’ouvrir. Quand je presse avec 2 doigts, il ne se passe rien (le couvercle ne s’enfonce pas). Et le couvercle a l’air bloqué (grippé). J’hésite à utiliser une pince pour le tourner. Mon AirTag est resté depuis son achat dans une poche étanche de mon sac à dos. Il ne sonne plus quand je déplace ce dernier mais sonne si je le localise. Cdlt.
Eugénie Grandet - crwdns2934203:0crwdne2934203:0
Eugénie, excusez mon français. Essayez de saisir l'AirTag des deux côtés avec quelque chose qui a de l'adhérence, comme du silicone. Appuyez ensuite vers le bas et tournez. Assurez-vous de tourner dans le bon sens. Bonne chance!
Carsten Frauenheim -
Well done! One thing to add is that the replacement battery must not have a bitterant coating as they are problematic with the AirTags.
petermg - crwdns2934203:0crwdne2934203:0
Removing the bitterant with some isopropyl (rubbing) alcohol works if you aren’t able to find unflavored batteries near by.
Collin Reisdorf -
after the change of battery does the AirTag work as before automatically or does it need to be re-associated with the iPhone?
BaijuDC - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 33
crwdns2936753:07crwdne2936753:0 271
crwdns2936753:030crwdne2936753:0 1,064
crwdns2942667:0crwdne2942667:0 60,794
