AirPods Charging Case Disassembly
  1. AirPods Charging Case Disassembly, AirPods Charging Case Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly, AirPods Charging Case Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly, AirPods Charging Case Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 这是一个进水的airpods充电盒,那就尝试把它拆完整开试试看
  2. AirPods Charging Case Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 找来常用的工具-镊子把它分成两半,然后用砂轮机打磨到所需要合理的长 宽 厚的尺寸,为接下来的顺利拆解做好准备!
  3. AirPods Charging Case Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 用手术刀,插入里面四周都要左右划动,让充电盒的连接部件充分松动,再翘出一条缝隙好,插入撬棍之类的工具
    To separate this part, I took a pair of needle-nose plyers and stick the ends down towards the columns where the base of the air pods sit. Clamp the plyers together and slowly extract, and it will come out scratch free. Just be sure to use a cloth in between the teeth of the plyers to avoid scratching the plastic when you squeeze down.
    Also note to not pull it out completely because you will rip other components apart.
    Joe Krajicek - crwdns2934203:0crwdne2934203:0
  4. AirPods Charging Case Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 用之前自己打磨好的专用金属撬棒,进一步翘松,然后用虎台钳固定,慢慢拧紧,让充电和外壳,发生形变,再进一步用工具松动,(记住固定前一定要塞橡胶防护airpods充电盒的外壳两边,避免虎台钳对外壳留下伤害印记)
  5. AirPods Charging Case Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 松动后用金属撬棒,在两边同时用力撬出,然后注意排线将内部底座取出来,最后用热风枪加热,将内部的不锈钢固定铁环其取出
    No way it is so easy as shown here. Sides are glued as well as the front, plus the force to pull it out needs to be against the outer shell, which causes a lot of stress to this part of the plastic. What is the thickness of these tools which you slide on each side?
    redex7 - crwdns2934203:0crwdne2934203:0
  6. AirPods Charging Case Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 将不锈钢固定铁环的取出后,接下来,用热风枪加热取出,指示灯和airpods耳机的充电触点底座
  7. AirPods Charging Case Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 加热充电触点底座后,用手术刀划开,粘接的部件,进一步松动,最后从底部撬开取出
  8. AirPods Charging Case Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 用热风枪加热,上盖金属连接部件,这里温度要稍微高一些,大概在90到100多度左右,加热20几秒后,(注意环境温度和加热,时间成反比)最后用尖嘴钳夹住金属连接扣两边,左右摇晃,用力拉出
  9. AirPods Charging Case Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 继续用热风枪加热后,用撬棒将电池松动部分,把固定连接排线底座上的压扣松动,取出电池
  10. AirPods Charging Case Disassembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 把电池取出后,拆开保护板的位置,对内部腐蚀的地方用洗板水清理,重新用DC可调电源充电激活
  11. AirPods Charging Case Disassembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 先用手术刀,将内部的,固定架左右滑动,使其粘接部件松动,也可以用加热方法一边滑动,一边加热,最后再配合之前打磨好的特殊金属撬棍用小锤用力向下敲击将外盒和内部固定架的粘接点剥离 松动
  12. AirPods Charging Case Disassembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 再继续重复之前的操作,直到完全松动,最后将内部的固定架取出
  13. AirPods Charging Case Disassembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 完整取出后,再用螺丝刀拆下,耳机底座连接排线和下面的lightning接口充电的排线
  14. AirPods Charging Case Disassembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 将主板所有连接部件都取下后,用水扣钳将电路板下面两边,白色塑料多余的上部分,用来固定电路板的支点剪掉
  15. AirPods Charging Case Disassembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 取下电路板后,可以看到电路板部分元件蚀非常严重,毕竟进水有很长时间了,
  16. AirPods Charging Case Disassembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 先用超声波清机,配合PCB洗板水,试试看能否挽救
  17. AirPods Charging Case Disassembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 清理后,先不忙上锂电池,连接电源看看指示灯有没有亮,
    • 很显然主板依然不能正常工作指示灯也未亮, 查看电流在六毫安左右,这种情况一般大多都是,电源芯片最容易损坏,看来需要重新将损坏的元件拆不过你需要,找到相同型号,的元件才可以,但,找不到没关系,可以重新,拆下原件重新植锡焊接碰碰运气了,这里针对专业人士,普通用户的话请看我的建议在文章最后~~~
    在文章最后没有找到啊
    wang - crwdns2934203:0crwdne2934203:0
  18. AirPods Charging Case Disassembly: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 差点忘记了这颗ifixit没有完全拆解的按钮,按钮的内部到底有什么秘密呢,顺便把他也拆开看看咯,可以看到采用了和iphoneSE iphone5以前手机实体Home键内部差不多相同的按键
  19. AirPods Charging Case Disassembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirPods Charging Case Disassembly: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 个人总结,aiepods充电盒拆解的意义主要是针对普通用户刚进水没多长时间的朋友,可以尝试用我这种方法拆解后,尽可能的在最短的时间内将,电池和内部电路板拆出来抢救,尽量挽回损失
    • 清理干净后再用吹风机,加热吹干后,测试能确认正常使用,没问题后再用B7000胶水粘接牢固即可使用啦! 希望能对各位朋友有所帮助!
    • 最后我想请问下ifixit拆解团队,现在起airpods可修复性为 0 的评分能否改一下了? ( ^_^ )
    Nice disassembly tutorial - reasonable enough! Now can you assemble it?
    patrick.babcock - crwdns2934203:0crwdne2934203:0
    What’s the power voltage transmission from the case to the AirPods when the case is charging the AirPods?
    Dj Smart - crwdns2934203:0crwdne2934203:0
    Acabo de comprar unos clon pero al abrirlos no encienden, al revisar el ticket dice que no tienen garantía por estar en rebaja, alguna sugerencia? Se podrán reparar? Los que muestras son diferentes para abrirlos por ser originales?
    Carla - crwdns2934203:0crwdne2934203:0
crwdns2935229:059crwdne2935229:0
deng lei
crwdns2935283:008/03/18crwdne2935283:0
3,344 crwdns2915208:0crwdne2915208:0
crwdns2947412:013crwdne2947412:0
66666,我看拆的過程中有一些部分損毀,請問還能裝回去麼?
zhewen - crwdns2934203:0crwdne2934203:0
,部分损伤只是内部的根本不影响,肯定可以装回的,用胶粘好完全看不出来,不影响使用,除非你打开盖子仔细看边上的划痕,但立刻用抛光砂纸打磨去掉
Deng lei -
我去 厉害的攻略! 我的airpod进水之后就搁置了。 准备试一下。请问如何控制热枪的温度?
Sheng Qu - crwdns2934203:0crwdne2934203:0
短时间内大概90-110度今天你自己感觉了手抹上很烫手且外壳未发生形变即可
deng lei -
Haha thats exactly what this article tought me too :D
Moritz Scheidenberger -
Sounds about right… ;-)
Way to much work.
iZPhoneMan -
Bonjours, ou trouver des pièces détaché pour airpod ?
kaius - crwdns2934203:0crwdne2934203:0
still looks like a “0” to me
Studio Harrison - crwdns2934203:0crwdne2934203:0
thinks that helped me out it works know.
Jeremy Gregory - crwdns2934203:0crwdne2934203:0
Thank you for this breakdown. A common issue is that the conductive metal at the bottom of the tube loses its springiness. This has resulted in one of my earbuds not charging. Otherwise, they've worked great. I plan to use these steps to hopefully repair it.
JohnJ - crwdns2934203:0crwdne2934203:0
mis audífonos son clon pero igual la info me ayudó á abrirlos
Leonardo Mendoza Chavez - crwdns2934203:0crwdne2934203:0
You are genius I have you 100points keep it up
Benjamin O. Ekpenyong - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 75
crwdns2936753:07crwdne2936753:0 630
crwdns2936753:030crwdne2936753:0 2,461
crwdns2942667:0crwdne2942667:0 344,820
