If the back case of your device is broken or keeps falling off and does not stay on, you will learn how to replace the backing in order to prevent any complications in the device.
Hold the device with an open corner available and facing you.
Using your finger, pry open any of the four corners of the back case of your AirCard 770S, until you see the back case disconnect from the device.
Lift open the back case and remove it from the device.
