The purpose of this guide is to provide instructions on replacing the front panel and gaining internal access to the controller of the Air Hog Smash Bots.
Take out your controller and access to the back of the controller.
Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
Use the plastic opening tool to disconnect the front and back parts of the panel.
