This guide will describe how to replace the motherboard in the controller.
Take out your controller and access to the back of the controller.
Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
Use the plastic opening tool to disconnect the front and back parts of the panel.
Using the PH #0 bit, remove two 8 mm screws on the main board.
De-solder the LED wires from the motherboard.
Lift the motherboard with a spudger to remove it from the case.
Hi,
Remot controller doesn't work.
Because my son used it into water.
So what should I do for fix it?
Thanks.
