Remove the battery cover.
Remove the batteries.
Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
Remove the four screws from the back side.
Remove the sticky black cover dot.
Remove the hidden screw.
Remove the two screws from the top side of the device.
Remove the two screws from the bottom side of the device.
Pull back the front cover so that you can dislodge the side cover.
Unfold the device and be careful not to tear the black and red power supply wires.
