Remove the battery cover.
Remove the batteries.
Remove the sticky black dots.
Remove the three black 4mm screws from the flip screen. Use a Phillips head screw driver.
Using an opening tool, separate the cover from the screen.
Using an opening tool remove the outside cover of the flip screen.
With the cover off, push the brown locking mechanism up, so the picture cable can be remove.
Remove the two black screws from the circuit board.
With the opening tool, pop up the screen assembly.
As in step 5, push up the brown locking mechanism of the remaining cable.
Unplug the picture cable.
Turn the circuit board over and with a soldering gun remove the two wires on each end.
With the wires no longer holding the circuit board and screen together, remove and replace the broken screen.
