Aiptek DZO-V58N Lens Protector Replacement
    1. Aiptek DZO-V58N Lens Protector Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the battery compartment on the back of the camera. It is the panel with the plastic ridges for simple removal.
      • Slide the battery compartment cover down off of the camera body.
    2. Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry up the battery from the bottom using a finger and remove the batter from the case.
    1. Aiptek DZO-V58N Lens Protector Replacement, Lens Protector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the lanyard by pulling the grey lace through the black string loop.
      • Pull black string loop through the silver bracket.
    2. Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to pry off the black control cover.
      • The face plates are glued, so use force to pry the face plates from the camera body.
    3. Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to pry off the ridged back face plate and the black button.
      • The button is loose and should come off with little or no effort.
    4. Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to pry off the silver face plate.
    5. Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Open the USB cover to expose the small machine screw.
      • Use the Phillips #00 screwdriver to unscrew the six 0.5cm machine case screws (distributed around the camera body).
      • These small screws are easy to lose. Place the removed screws in an organized container to avoid losing them.
    6. Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull off the side control panel.
    7. Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip open the screen by pulling the loose end of the screen away from the case.
      • Use tweezers to remove the two outside rubber dots to reveal the two 0.5cm machine screws.
      • Use the #00 Phillips Screwdriver to remove both screws.
    8. Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aiptek DZO-V58N Lens Protector Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the body apart from the bottom of device just enough to make space to remove the silver plastic strap holder.
      • Use tweezers to remove the silver plastic strap holder.
      • Use a plastic opening tool to pry off the lens protector.
Zachary Yun
crwdns2935283:004/03/12crwdne2935283:0
28 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-5, Forte Spring 2012 crwdns2935289:0Cal Poly, Team 5-5, Forte Spring 2012crwdne2935289:0
CPSU-FORTE-S12S5G5
crwdns2942667:0crwdne2942667:0 984
