The replacement of the motherboard requires the complete removal of the battery, trigger buttons, joy sticks, and vibrations motors. All of which will require soldering for removal.
Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
Lift up and remove the controller back plate.
Desolder the battery connection from the motherboard.
Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
Detach the main motherboard fom the front pate by carefully pulling it off.
Remove two button padding from the back of motherboard.
Desolder the four button connections from the motherboard.
Desolder the joy stick connections located on the front.
