crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
crwdns2959928:0crwdne2959928:0 ↓In order to replace the joysticks for the Afterglow Wireless PS3 Controller the back plate must be removed and the joystick boards must be unscrewed.
Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
Lift up and remove the controller back plate.
Carefully remove the battery by lifting it straight up from its place.
Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
Jiggle both joy stick control mini-motherboards out of their holding place.
Firmly grip the joystick housing with your forefingers by the yellow squares.
Use your other hand to get a grip on the black plastic joystick and pull directly away from the housing.
crwdns2935229:012crwdne2935229:0
