Replacing the battery in a PS3 Wireless Afterglow Controller requires the removal of the back plate and then the soldering of the battery wires onto the motherboard.
Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
Lift up and remove the controller back plate.
Carefully remove the battery by lifting it straight up from its place.
Use the soldering tool to heat the solder connecting the battery wires to the motherboard.
