Adjusting the bowl height
  1. Adjusting the bowl height, Adjusting the bowl height: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Safety first! - Unplug the mixer, the first rule in any electronic repair.
    • Prepare a cloth and turn the unit upside down making sure it is secure and that it is not being scratched.
  2. Adjusting the bowl height: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the unit upside down unscrew the four indicated screws using a fairly large Phillips Screwdriver
    • Secure the base with one hand while removing the last screw as it may fall.
    • After removing the screws remove the base and place it in a safe place. Beware that it may be dirty/oily in the uncovered area. Clean as necessary.
    • The 4 screws that need to be removed
  3. Adjusting the bowl height: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Adjusting the bowl height: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The removal of the base gives access to the adjusting screw.
    • Tightening will raise the bowl position, loosening the screw will lower the bowl position.
    • The 11mm screw that needs to be adjusted.
To reassemble your device, follow these instructions in reverse order making sure that before tightening the Phillips screws the base is aligned as it was before to prevent any visible lines where paint may be missing/damaged that were previously covered by the alignment of the base.
Dan Mihai Ile
crwdns2935283:010/16/12crwdne2935283:0
186 crwdns2915208:0crwdne2915208:0
That isn't an adjustment screw for the bowl height you ridiculous clown.
It adjusts the tension of the handle mechanism as it locks the bowl into place.
Hobart N50's have no bowl adjustment. The lift arm literally stops against the neck casing in an exact spot.
Snap Oh - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,939
