Adjusting iRobot Braava Jet 240 magnetic contact sensors
  1. Adjusting iRobot Braava Jet 240 magnetic contact sensors, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device off.
  2. Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently pop out the battery.
  3. Adjusting iRobot Braava Jet 240 magnetic contact sensors, Mop Pad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors, Mop Pad: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the handle to reveal the eject button.
  4. Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger to push the eject button forward.
  5. Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the robot on its side and let the mop pad slide out.
  6. Adjusting iRobot Braava Jet 240 magnetic contact sensors, Front Shell: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors, Front Shell: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
  7. Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull back on the front shell to remove it from the robot.
  9. Adjusting iRobot Braava Jet 240 magnetic contact sensors, Back Shell: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors, Back Shell: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a Phillips #1 screwdriver through the screw holes.
    • Unscrew the two 9.7 mm screws.
  10. Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 9.7 mm screws using a long neck #1 Phillips screwdriver.
    • If the screws are unscrewed but do not come out easily, turn the robot upside down and gently shake it.
  11. Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the back shell to remove it from the robot.
    • For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal.
  12. Adjusting iRobot Braava Jet 240 magnetic contact sensors, Remove pad ejection lever spring: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors, Remove pad ejection lever spring: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors, Remove pad ejection lever spring: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First pull up, then pull down on the spring to detach it from the hooks.
  13. Adjusting iRobot Braava Jet 240 magnetic contact sensors, Remove the motherboard case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors, Remove the motherboard case: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Adjusting iRobot Braava Jet 240 magnetic contact sensors, Remove the motherboard case: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up on the motherboard case and pull it forward to remove it from the device. This will expose the free-floating platform, as well as motors, water tubing, and the magnetic sensor pads.
  14. Adjusting iRobot Braava Jet 240 magnetic contact sensors, Adjust the height of the magnetic locating pads: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the magnets to raise them up with respect to the free-floating platform, but not so much that they rub against the bottom of the motherboard case.
    • The idea is to shrink the gap between the magnet and the motherboard case so as to improve the performance of the inductive sensor.
Elven Decker
crwdns2935283:004/18/22crwdne2935283:0
291 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 622
