Adjust Goose-neck (adjustable quill stem) on Specialized Expedition
  1. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition, Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bolt cover with a flathead screwdriver.
  2. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the goose-neck (adjustable quill stem) with a 6 mm Allen wrench.
    • After loosening the goose-neck (adjustable quill stem), it still may be stiff. Hold the wheel from turning and twist the handlebars from side to side.
    • If quill stem is still stuck then place 6 mm Allen wrench firmly into bolt and tap with a mallet.
    • Position the handlebars to your preferred height. Make sure not to pull cable and housing to tight. I could adversely effect shifting and braking performance.
    • Make sure you don't raise quill stem above minimum insert line.
  3. Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Adjust Goose-neck (adjustable quill stem) on Specialized Expedition: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the direction of the goose-neck (adjustable quill stem) with the front tire.
    • Firmly tighten the goose-neck (adjustable quill stem) bolt using a 6 mm Allen wrench.
    • Pop the bolt cover back on.
    • If calling a bicycle repair shop, refer to it as a adjustable quill stem (technical term) instead of goose-neck as mechanic may not know what you are talking about.
aaron thielk
crwdns2935283:010/10/10crwdne2935283:0
1,924 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-13, Maness Fall 2010 crwdns2935289:0Cal Poly, Team 5-13, Maness Fall 2010crwdne2935289:0
CPSU-MANESS-F10S5G13
crwdns2935297:018crwdne2935297:0
Anyone know where/how to buy a replacement bolt cover?
Bennett Hart - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,508
