crwdns2936621:0crwdne2936621:0
crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0ActivPAL 3crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. ActivPAL 3 Teardown, Some information about the device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ActivPAL 3 Teardown, Some information about the device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With no user interface, this device is built for purpose. Strapped to the thigh using an adhesive patch, this device continuously measures movement and position of the limb to calculate physical activity intensity, storing data locally on the device for upto 14 days (as per their claims) .
    • Width: 35mm
    • Length: 54.7mm
    • Height: 7mm
  2. ActivPAL 3 Teardown, Open the casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ActivPAL 3 Teardown, Open the casing: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ActivPAL 3 Teardown, Open the casing: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The casing consists of two injection molded plastic parts which have been sealed with an adhesive. To open the device, the parts were heated with a hair dryer to loosen the adhesive. Then a prying pick was used to release the two parts. Prying was started at the micro-USB port and then used all around the seam.
    • Inside the device, there was a battery and a PCB placed side-by-side.
    • The device communicates through a micro-USB port. It is not a water-resistance device as the USB port is exposed.
  3. ActivPAL 3 Teardown, PCB with a layer of EVA-based glue: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ActivPAL 3 Teardown, PCB with a layer of EVA-based glue: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The PCB had been covered in a layer of EVA-based hot glue to protect the components from moisture and any liquid which may damage it.
    • The glue would also help in holding the connections and components in place within the casing.
  4. ActivPAL 3 Teardown, Removing the EVA-based glue from the PCB: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ActivPAL 3 Teardown, Removing the EVA-based glue from the PCB: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ActivPAL 3 Teardown, Removing the EVA-based glue from the PCB: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The EVA glue was removed by scraping using a plastic spudger and then pulling the glue off using tweezers.
    • Width: 29mm
    • Length: 30mm
    • Be careful while scraping the glue. It is possible to poke yourself with the spudger. Always scrape away from your fingers!
    • Dispose of the glue residue from the scraping. Keep away from children and pets.
    • This is not the most efficient way to remove the glue. It took 20 minutes of scraping. One capacitor also came off while removing the glue.
    • Alternative chemical methods may be more useful in this step, but they may be difficult to obtain locally and not suitable for home use.
  5. ActivPAL 3 Teardown, Studying the PCB components: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ActivPAL 3 Teardown, Studying the PCB components: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  6. ActivPAL 3 Teardown, Studying the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ActivPAL 3 Teardown, Studying the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The device is powered by a 3.7V 250mAh Lithium Polymer battery
    • Length: 29mm
    • Width: 20mm
    • Thickness: 5.5mm
    • The battery had a PCB connected to it containing two components:
    • 8205A 1011HC (5A 20V N-Channel MOSFET)
    • DW01 (Battery management IC)
    • This module protects the battery from over-charging and over-discharging, allowing a stable power supply to the device.
  7. ActivPAL 3 Teardown, Teardown complete: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • That is the full product disassembled!
    • In terms of repairability, it is possible to open the casing without damaging it, but it requires the tools listed in this teardown. It can then be glued back together with a glue gun or super glue.
    • The battery is soldered onto the PCB, so replacing the battery requires a soldering kit. This is also true for replacing ICs or components on the PCB.
    • The device comes with a charging dock for upto 10 devices, but the micro-USB port should allow direct connectivity with computers for data transfer and charging.
OpenDesign
crwdns2935283:010/16/23crwdne2935283:0
442 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 142
