crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Actiontec Q1000 DSL Modemcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Actiontec Q1000 Teardown, Actiontec Q1000 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown, Actiontec Q1000 Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown, Actiontec Q1000 Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Qwest Q1000 modem, made by Actiontec.
    • Port side with antennas detached.
    • DSL and Phone in ports
    • 4 Ethernet ports
    • USB port, reset button, and power jack
    • Not a screw in sight.
  2. Actiontec Q1000 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As usual, the rubber feet are hiding screws!
  3. Actiontec Q1000 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Nothing really to see here...
    • Remove the 2 antenna wires from the wifi card. One is also taped to the back of the board.
    • The circuit board is finally free!
  4. Actiontec Q1000 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Looks like someone was generous with the thermal paste.
    • Underneath the cover:
    • Broadcom BCM6366
    • Broadcom BCM53115
  5. Actiontec Q1000 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Wi-Fi card lets down its shield...
    • The chip is a BCM4322.
  6. Actiontec Q1000 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The inside of the top case.
    • The antenna connectors are screwed onto the case.
  7. Actiontec Q1000 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The antenna connectors have gold-plated coax connectors and standard Wi-Fi antenna connectors.
    • What's underneath the heat-shrink? A ferrite bead to minimize interference.
  8. Actiontec Q1000 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Testing out the light pipe with an LED throwie...
    • The light pipe takes light from tiny surface-mount LEDS on the motherboard and refracts it to the panel.
    • Here are all the LEDS:
    • 8 of the LEDS that work with the light pipe
    • One more surface mount LED
    • A white LED for illuminating the Qwest logo
    • A dual-color (red/green) LED for the WPS status indicator.
  9. Actiontec Q1000 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Actiontec Q1000 Teardown: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The empty shell that once held a DSL modem.
    • The 2 detachable Wi-Fi antennas. Nothing to tear down here!
  10. Actiontec Q1000 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repairability score: 8/10
    • The entire device is held together with only 4 screws.
    • The Wi-Fi antenna connectors are screwed in and the cables are not soldered to the board.
    • The antennas are replaceable as well.
    • The heat sink is soldered in place, making removal difficult.
    • The Wi-Fi card is soldered in and held in place with silicon adhesive, making it impossible to remove without damaging the card or the device.
crwdns2935103:0crwdne2935103:0
jdp23
crwdns2935283:008/22/13crwdne2935283:0
1,312 crwdns2915208:0crwdne2915208:0
crwdns2935297:023crwdne2935297:0
Awesome teardown! These things have gotten so simple. Those antennas would be pretty easy to repurpose for something else.
Kyle Wiens - crwdns2934203:0crwdne2934203:0
What are the part number, volts, and amps of the power supply?
PDXTek - crwdns2934203:0crwdne2934203:0
Hello. I have one of these that I want to switch the antenna for. Are you able to tell me which of the antenna wires is the positive and neutral (I realize the antenna itself doesn’t have positive & neutral, but I don’t know the relevant term). Both wires are grey and hooked together so it’s not easy to tell
https://d3nevzfk7ii3be.cloudfront.net/ig...
earthscope - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 6,712
