AcousticSheep SleepPhones Battery Replacement
  1. AcousticSheep SleepPhones Battery Replacement, Take out the Bluetooth module: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Just like when charging the device, take out the Bluetooth module from the headband and disconnect it from the speakers.
  2. AcousticSheep SleepPhones Battery Replacement, Pry off the back of the module: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AcousticSheep SleepPhones Battery Replacement, Pry off the back of the module: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The back cover is glued in place. It's not a very tough glue, so the cover may have already shifted a bit from its place, and it shouldn't be too hard to remove.
    I'm opening an ASL06 (ASL06_H0 marking on the PCB) from some time before year 2020. It only has a 175mAh battery :O
    Full marking:
    5PB0E322826
    175 mAh 3.7V
    0.6475Wh 1708
    Thomas - crwdns2934203:0crwdne2934203:0
    • The module has two compartments, one for the battery and one for the circuit board. Remove both from their rubbery shell.
    • You may be able to cleanly remove the two wires from the beige clip, but I wasn't confident I would be able to reconnect them, so I cut them near the battery, so I had plenty of wire to attach the new battery to.
    • The original battery is a prismatic LiPo 3.7 V 330mAh with dimensions 4x28x26 mm
    • I wasn't able to find one of that exact size, but since it fit even in its swollen state, I figured I could go for a thicker 6x28x23 mm battery
    I ended up selecting ICP602823PA-01 as well.
    Looking at Distrelec, they only had Renata LiPos. Here are the ones filtered for width<=29, length<=28 from https://media.distrelec.com/Web/Download...
    Cell_Model_______Part_No._Thickness_Width__Length_Typical_Capacity_(mAh)
    ICP241019________100290___2.40______11.20__19.30___25
    ICP341018PM______100730___3.70______10.20__19.50___35
    ICP331319PM______100735___3.75______12.60__20.30___50
    ICP501022UPM_____100640___5.50______10.00__24.00___80
    ICP641414PE______100694___6.70______14.90__16.80___95
    ICP501421PS______100690___5.20______14.10__22.50___115
    ICP651321PA-01___100696___7.00______13.20__23.50___120
    ICP521522PS*_____100935___5.70______15.50__23.50___135
    ICP581323PA-01___100692___6.20______13.20__25.00___145
    ICP402025PC-01___100644___4.30______20.50__27.50___155
    ICP641620PA-01___100695___6.90______16.20__21.50___165
    ICP602823PA-01___100697___6.40______28.20__25.50___350
    It turned out that on both of the two devices I was looking at, both had problems with loose contact in the beige battery cable connector. The battery on my newer device was still fine, I just had to carefully swap the leads between the connector, so that I had one with two functioning leads and one with two loose/nonworking leads.
  3. AcousticSheep SleepPhones Battery Replacement, Connect the new battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder or twist together the old and new battery wires
    • Cover the exposed parts with electrical tape
    I prefer to use heat shrink tubing for this as it does not have the risk of starting to unwind.
    • You can test your repairs without replacing everything into its protective cover first. This can save you some frustration when it doesn't work on the first try, but requires a bit more caution when handling the circuit board.
    • Long press the central button on the circuit board to turn it on. Does the red LED blink on?
    • Does it connect to your device?
    • Attach the speakers and try to play some audio
    • Attach a charger. Does the charging light come on?
  4. AcousticSheep SleepPhones Battery Replacement, Replace the components back into the rubber case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can look at the opening for the USB port to check the orientation (this is one place where USB-C would be a disadvantage)
    • It might take some patience to guide the wires through the opening between the two compartments. In my case it was easier to turn the battery sideways.
    • In my case, it remained sticky enough to not require new glue, even after several disassemblies.
hgjd
crwdns2935283:006/17/22crwdne2935283:0
224 crwdns2915208:0crwdne2915208:0
I ended up removing the bad battery connector altogether from the battery wires. Then I soldered the negative side to the capacitor just below the connector on the board, and the positive side to the positive pin in the board connector. Finally I managed to get some glue gun glue on it.
https://imgur.com/a/sCySO7Q
Do you have a link to the supplier of the replacment battery?
Joe Noir - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 1,906
