Learn how to remove the Acer X191 back cover, to replace it, or get the the components inside.
Lay the monitor on a flat surface, facedown.
Use a #1 Phillips screwdriver to remove the 4x 10.2mm screws securing the stand to the back panel.
Remove the stand from the back panel by pulling it up.
Remove the 2x 9.8mm Phillips #1 screws securing the back cover to the monitor.
Work your way around the monitor, putting the flathead screwdriver into the space between the front and back covers, and prying up.
Ideally you want to pry at the locations that have the little gaps, which are locking mechanisms.
I've highlighted the locations of the locking mechanisms for the back cover, try prying in these locations for the best results.
Right side of the monitor.
Top of the monitor.
Left side of the monitor.
Bottom of the monitor locking mechanism locations.
The monitor back cover will then pull right off.
