Use this guide to replace a faulty battery in your Acer Swift 3 2022.
Model Number: N20C12
The battery is the piece of hardware that powers the laptop. A faulty battery could cause the laptop to not turn on or only work when it is plugged in. Before replacing, be sure to power down your device. To view more information view our troubleshooting page.
Flip the device over so the bottom panel is facing up.
Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
Use the iFixit opening tool to pry open the back of the device.
Remove the bottom cover from the laptop.
Peel back the strip of black tape.
Unplug the group of wires by pulling the white plastic piece towards yourself.
Remove the two 5 mm screws on the sides of the battery using a TR6 Torx screwdriver.
