Acer Spin 5 SP515-51GN-807G Motherboard Replacement
  1. Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eleven 6.5 mm screws that secure the back case using a Phillips #1 screwdriver.
  2. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to gently pry open the back cover.
  3. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the back cover from the device.
  4. Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, remove the piece of black tape over the battery cable connector.
  5. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the piece of black tape that covers the battery.
  6. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the battery cable on both sides with your fingertips and gently pull it away from the port.
    • If needed, use the plastic opening tool to remove the cord from its port.
  7. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 3.5 mm screws that secure the battery using a Phillips #00 screwdriver (PH00 bit).
  8. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully place your fingers under the plastic lip where the screws were removed.
    • Lift upwards to remove the battery.
    • Do not bend or puncture the lithium ion battery as it poses a fire hazard.
  9. Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Fan: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the piece of tape covering the fan screw using a pair of tweezers.
    • This can also be done using your fingernail.
  10. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
  11. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3.5 mm screw connecting the fan to the computer using a Phillips #00 screwdriver (PH00 bit).
  12. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the fan with your fingers by the edges and lift up to remove the fan.
  13. Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your fingernail underneath the locking tab of the ZIF connector holding the interconnect cable on the USB/Side Port board.
    • Lift the black clamp upwards to release the cable.
  14. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the USB/Side Port Board cable away from the port.
  15. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grasp the cable that connects the speakers to the motherboard.
    • Gently pull the cable away from the motherboard.
  16. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the tape covering the cable port.
    • This step can be completed using either your fingernails or a set of tweezers.
  17. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grasp the cable.
  18. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  19. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one 3.5mm screw that secures the wireless card using a Phillips #00 screwdriver (PH00 bit).
  20. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the wireless card away from the motherboard.
  21. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your fingernail underneath the black tab which secures the cable in the ZIF connector.
    • Lift the black tab upwards to release the cable.
  22. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  23. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your fingernail underneath the black clamp which secures the cable.
  24. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  25. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the two white clamps on each side of the cable with your fingernails and pull away from the motherboard to release the cable.
  26. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 3.5mm screws that secure the heatsink using a Phillips #00 screwdriver (PH00 bit).
  27. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.5mm screws that secure the heatsink using a Phillips #00 screwdriver (PH00 bit).
  28. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the heat-sink unit upwards and remove it from motherboard.
    • Do not power on your laptop with the heat-sink unit removed as this will cause heat damage to your processor.
    • When removing a heat-sink unit from the processor (CPU), follow the steps on Applying Thermal Paste before reinstalling the heat-sink and powering on the device.
  29. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the tape covering the port.
  30. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your fingernail underneath the black clamp that secures the cable to the ZIF connector.
    • Pull the cable away from the motherboard.
  31. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the cable on either side with your fingertips and gently pull away from the port.
  32. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 3.5mm screws that secure the motherboard to the laptop using a Phillips #00 screwdriver (PH00 bit).
  33. Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 SP515-51GN-807G Motherboard Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard from the laptop.
James Wasielewski
crwdns2935283:001/24/20crwdne2935283:0
1,066 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S3-G4, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S3-G4, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S3G4
crwdns2942667:0crwdne2942667:0 1,451
