Acer Spin 5 N17W2 Hard Drive Replacement
  1. Acer Spin 5 N17W2 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 N17W2 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
    Not sure how you removed the back cover with a Philips head. Those are Torx screws. I actually came here to see what size Torx bit I need. Guess I won't find it here.
    Brad F - crwdns2934203:0crwdne2934203:0
  2. Acer Spin 5 N17W2 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 Hard Drive Replacement, Hard Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the hard drive and remove it from the device.
    • At the time of guide creation, the hard drive was not included in the device.
William Turner Childress
crwdns2935283:002/20/20crwdne2935283:0
73 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G18, Eggleston Spring 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G18, Eggleston Spring 2020crwdne2935289:0
CMCSC-EGGLESTON-S20S3G18
You highlighted some random spot for the hard drive but you should have highlighted the empty m.2 slot which doesn’t even require you to remove the battery.
Peter Iliopoulos - crwdns2934203:0crwdne2934203:0
Agreed. This guide is pointless. Just a random, inaccurate guess. Why even bother putting this together if you don't know what you're talking about.
Stephen Feger - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,017
