The hard drive is the storage component of a laptop or computer. If you’re unable to read files or access files in your computer, your hard drive may be corrupted and needs to be replaced. Use this guide to replace the hard drive in your device.
Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
Use an opening tool to pry the back cover open.
Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
Carefully remove the three tapes on the battery.
Carefully slide the battery connector out of its motherboard socket.
Disconnect the hard drive and remove it from the device.
You highlighted some random spot for the hard drive but you should have highlighted the empty m.2 slot which doesn’t even require you to remove the battery.
Agreed. This guide is pointless. Just a random, inaccurate guess. Why even bother putting this together if you don't know what you're talking about.
Not sure how you removed the back cover with a Philips head. Those are Torx screws. I actually came here to see what size Torx bit I need. Guess I won't find it here.
Brad F - crwdns2934203:0crwdne2934203:0
