Acer Spin 3 SP315-51-757C Motherboard Replacement
  1. Acer Spin 3 SP315-51-757C Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove eleven Phillips #0 screws from the back panel.
  2. Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening tool, pry open the back panel, starting at the silver screen hinges.
    • You may need to apply more force than usual. If you don't find any success at the hinges, you can try to start at another area that looks easier to open.
    • You can also use some plastic opening picks to help hold parts of the panel open while you work on other sides.
  3. Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back panel off of the laptop.
  4. Acer Spin 3 SP315-51-757C Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips #0 screws holding the battery inside the laptop case.
  5. Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using either your hands or a pair of tweezers, carefully pull the battery's cable out of its motherboard port.
  6. Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, lift up on the battery from its slot, and carefully slide it away from you before fully lifting it out of the case.
  7. Acer Spin 3 SP315-51-757C Motherboard Replacement, Charger Port: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The charger port's inner cable may be covered by a manufacturer sticker, which can be easily removed.
    • Using your nails or tweezers, unplug the charger port cable from the motherboard.
  8. Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the charger port out of its slot in the laptop casing.
  9. Acer Spin 3 SP315-51-757C Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the three black tabs to release the cable connectors.
    • After the tabs are lifted, the white cables with blue ends can be pulled out of their slots.
  10. Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cables near the fan by pulling them carefully out of their slots.
  11. Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single Phillips #0 screw.
    • Unplug the speaker cable.
    • Unplug the secondary speaker cable.
  12. Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three Phillips #0 screws attached to the motherboard.
  13. Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 3 SP315-51-757C Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove four screws from the heat sink.
    • Carefully slide the motherboard from under the heat sink (it is easiest to slide the motherboard to the right).
Skyler Ognibene
crwdns2935283:009/17/19crwdne2935283:0
937 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S20-G2, Branham Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S20-G2, Branham Fall 2019crwdne2935289:0
ERAU-BRANHAM-F19S20G2
crwdns2942667:0crwdne2942667:0 2,576
