Acer S200HL LCD Monitor Motherboard Replacement
  1. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Stand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the monitor screen face down.
    • Firmly hold the base of the stand with one hand and the bottom of the monitor with the other hand.
    • Pull the stand away from the monitor.
  2. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer S200HL LCD Monitor Motherboard Replacement, Removing the Back Panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to pry the back panel from the front panel.
    • Start at one point of the crease and pry along the edge of the entire monitor for the best results.
  3. Acer S200HL LCD Monitor Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift back panel away from the monitor.
  4. Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer S200HL LCD Monitor Motherboard Replacement, Removing Interior Motherboard Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Be sure to keep track of where you place your screws. A magnetic mat is great for keeping your screws in one spot.
    • Unscrew the four 7.5 mm Phillips #2 screws connecting the motherboard to the metal casing.
  5. Acer S200HL LCD Monitor Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer S200HL LCD Monitor Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 10 mm hex screws.
  6. Acer S200HL LCD Monitor Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard casing from the monitor.
  7. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Connections to the Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The following steps circled in yellow are the locations for detaching the three connectors shown in the picture.
    Good morning sir my monitor mother board damaged sir.so please I want a mother board sir,how is getting and how much cost sir please tell me sir
    Model :S200HL
    LCD Monitor
    AAKULA NAGARAJU - crwdns2934203:0crwdne2934203:0
  8. Acer S200HL LCD Monitor Motherboard Replacement, Removing the No Fuss Ribbon Cable Connector: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black seal to release the small ribbon connector (the No Fuss Ribbon Cable connector) from the motherboard.
    • The connector will be released from the motherboard immediately.
  9. Acer S200HL LCD Monitor Motherboard Replacement, Removing the ZIF Connectors: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the black seal to release the large ribbon connector (the ZIF connector).
  10. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Bundled Cable Connector: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the bundled cable connector gently away from motherboard.
  11. Acer S200HL LCD Monitor Motherboard Replacement, Removing the Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard to remove it from the monitor.
Jeffrey Kong
crwdns2935283:009/22/14crwdne2935283:0
864 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-3, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 12-3, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S12G3
como saber si es la board o las lamparas q trae la pantalla?
y cual es la forma de reparar las lamparas
Doc acvdo - crwdns2934203:0crwdne2934203:0
What is the specific name of that dc-in power jack?I’ m trying to replace that thing with a new one,the current one is already faulty.Can u recommend me where to find that part?Thanks!
Oreo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 7,674
