Acer Predator 17 G9-791 Bottom Case Replacement
  1. Acer Predator 17 G9-791 Bottom Case Replacement, Service Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
  2. Acer Predator 17 G9-791 Bottom Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Predator 17 G9-791 Bottom Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the two Phillips #0 screws.
    • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
  3. Acer Predator 17 G9-791 Bottom Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue pulling up on the panel to separate it from the laptop and remove it.
  4. Acer Predator 17 G9-791 Bottom Case Replacement, Bottom Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Predator 17 G9-791 Bottom Case Replacement, Bottom Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Predator 17 G9-791 Bottom Case Replacement, Bottom Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the nine 4.5 mm Phillips #0 screws from the panel.
    • Remove four 14 mm Phillips #0 screws.
    • Remove six 7 mm Phillips #0 screws.
  5. Acer Predator 17 G9-791 Bottom Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the "unlock" slider up located to the right of the service panel and pull the disc tray out.
  6. Acer Predator 17 G9-791 Bottom Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.5 mm Phillips #0 screws located underneath the removed optical drive.
  7. Acer Predator 17 G9-791 Bottom Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Predator 17 G9-791 Bottom Case Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up on the edges of the bottom cover and lift the bottom case off of the device.
Matthew Shane
crwdns2935283:010/25/22crwdne2935283:0
376 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 crwdns2935289:0UMass Dartmouth, Team 5-1, Sinclaire Fall 2022crwdne2935289:0
UMASSD-SINCLAIRE-F22S5G1
crwdns2942667:0crwdne2942667:0 586
