Acer One 10 S1002 145-A Motherboard Replacement
  1. Acer One 10 S1002 145-A Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that the tablet is turned off and disconnected from any power source.
    • Disconnect the tablet from the keyboard attachment.
    • If you have a Micro SD card in the tablet, remove it now.
    • Remove the two 3.5 mm Phillips #0 screws on either side the keyboard connection.
  2. Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting from a corner of the tablet, use the plastic opening tool to create a gap between the screen and the back covering.
    • Slowly maneuver the plastic opening tool along the perimeter of the tablet to pry the screen and back covering apart.
    • Separate the back covering from the screen.
    Doing this, i’ve broke some of the “hook” thing that keepsthe plastic back plate to the screen, so now is loose and not well closed. How can I solve it?
    Lorenzo Giraudi - crwdns2934203:0crwdne2934203:0
    I need motherboard for Acer one 10 s1001
    Abdul Majeed Hajam - crwdns2934203:0crwdne2934203:0
  3. Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off all of the Polyimide tape (yellow tape).
    • Remove the metallic tape covering the keyboard connection.
  4. Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 3.5mm Phillips #0 screws and open the ZIF latch.
    • Gently remove the silver part covering the battery and set it aside.
  5. Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  6. Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4mm screws at the corners of the motherboard with the Phillips#0 bit screw.
    • The screw beneath the metallic tape also needs to be removed.
  7. Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three cables on the motherboard closest to the battery.
    • These cables require some extra prying power to be removed.
  8. Acer One 10 S1002 145-A Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide out the motherboard and put it aside.
crwdns2935229:014crwdne2935229:0
Shannon Griffin
crwdns2935283:010/03/16crwdne2935283:0
1.420 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Sullivan Fall 2016 crwdns2935289:0USF Tampa, Team 1-3, Sullivan Fall 2016crwdne2935289:0
USFT-SULLIVAN-F16S1G3
crwdns2947412:011crwdne2947412:0
WOW. Thank you so much for this guide. My keyboard wasn't connecting and last time I had to send it to Acer ...and that took a month. This time it is out of warranty and it wouldn't connect again!!!.... After opening it following this guide, it was immediately visible that the cable was out.
Thank you SO much!
Alen Mijic - crwdns2934203:0crwdne2934203:0
Hey,
Whenever you see a 'put aside' anywhere in a guide there's an implied 'then continue' afterwards.
Hope that helps!
Allen Tools -
Great help. Was able to restore connection for my grandson’s computer using your clear concise directions. THANK YOU!!!
Linda Byars - crwdns2934203:0crwdne2934203:0
how can i fix my acer one s1002 keyboard dock it is not working if i connect it to the tablet i
Wencel Angelo Maturan - crwdns2934203:0crwdne2934203:0
me salvaste la vida! graciasss
Beto Valdivia - crwdns2934203:0crwdne2934203:0
Me salvaste la vida!!!!!!!!!!!
worked perfect to fix my daughters keyboard
Shayla Moran - crwdns2934203:0crwdne2934203:0
OK, just out of warranty, 3 years from Costco, and went crazy trying to find out if a software upgrade left me disconnected. This video, and 15 minutes later, working again. The ribbon connector to the edge pins was the problem, lifted the black lock bar, pushed the ribbon cable back in position, and resnapped the black lock bar. A huge thanks for this video..
mapleridge240 - crwdns2934203:0crwdne2934203:0
Thank you so much . My keyboard wasn't conneced and After opening it following this guide, it was immediately visible that the cable was out.
thank you so much
vigyan singh - crwdns2934203:0crwdne2934203:0
Any idea what the correct part number or spec for the power connector on the mother board is. Center pin was broken on parents and am trying to find replacement to get up and running for them.
jasonquintal - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 18,937
